GeoRSSFeatureComposer
Constructs GeoRSS documents from the input features and stores them in the specified attribute for the features that are output by the GeoRSS port. The constructed GeoRSS document will be created according to the specified Geometry Format and Output Format, in the character set specified by the Output Character Set parameter.
For any given GeoRSS document, the metadata for the feed.
The entry features from the input GeoRSS document/feed.
The features containing the GeoRSS document in the attribute specified by the GeoRSS Attribute parameter.
The GeoRSS document that is being constructed accumulates features until the value specified for the feature Flush Attribute. When this occurs, the newly received input feature is not part of the flushed document, but rather is part of the next document to be constructed.
This attribute contains the GeoRSS document.
Choose the format of the XML feed that the GeoRSS writer will produce:
- Atom: the writer will produce an Atom 1.0 feed.
- RSS: the writer will produce an RSS 2.0 feed.
Choose the format of the output feed’s geometry extensions: GML, W3C, or Simple.
This parameter determines how the writer handles HTML content. Select Yes to ensure that the writer will escape HTML content before outputting it. Select No to ensure that the writer will output the content unchanged.
The character set encoding in which the output XML feed should be written. If no character set is specified, the feed will be written in the UTF-8 character set. If an invalid character set is specified, the translation will fail.
Transformer Categories
FME Licensing Level
See the FME Community for additional information about GeoRSS and FME.
Technical History
Associated FME function or factory: GeoRSSFactory
Search FME Community
