FilenamePartExtractor
Extracts specified parts of a filename path and returns the results as string attributes.
The attribute that holds the full filename and path.
If specified, this attribute will contain the full folder path of the Source Attribute, excluding the Full Filename.
If specified, this attribute will contain the full filename (including extension) of the Source Attribute.
If specified, this attribute will contain the root filename (without extension) of the Source Attribute.
If specified, this attribute will contain the extension of the file specified in the Source Attribute.
If specified, this attribute will contain the folder name of the file specified in the Source Attribute.
When parsing the path, both backslashes and forward slashes are handled as separators, regardless of operating system.
Example
For example, the path
C:\WINNT\Profiles\user\Desktop\roads.shp
would be extracted as follows:
Folder Path | C:\WINNT\Profiles\user\Desktop\ |
Full Filename | roads.shp |
Filename Root | roads |
Filename Extension | shp |
Folder Name | Desktop |
Transformer Categories
Technical History
Associated FME function or factory: @Filenamepart
Search FME Community
