EnvironmentVariableFetcher
Fetches the specified environment variable and includes it in a new attribute.
Environment variables are convenient especially if certain standard folders and parameters need to be referenced in a workspace, but the actual locations or names can vary from computer to computer.
The available variables will depend on which platform you are using. For example in Windows you can find a list of variables on your system by opening Control Panel > System > Advanced (or Advanced system settings link in Vista)> Environment Variables.
Type the environment variable name (for example, PATH or TEMP).
If the specified environment variable does not exist, an empty string is put into the given attribute.
Within an FME workspace you could use the value retrieved to:
- Define the output location of a dataset (in conjunction with Feature Type Fanout, which is described in the Workbench help files)
- Define the location of a file for the AttributeFileWriter or AttributeFileReader
- Define the location of a workspace to run with the WorkspaceRunner
- Write the value to some type of metadata output
Transformer Categories
Transformer History
This transformer has been renamed from EnvironmentVariableRetriever.
Technical History
Associated FME function or factory: @Tcl2
Search FME Community
Tags Keywords: EnvironmentVariableRetriever
