3DForcer
Turns two-dimensional data into three-dimensional data by adding a z-value to every coordinate.
Output features that have been converted to a three-dimensional form.
You can enter the parameter as a floating point number, or choose it from the value of a feature attribute by selecting the attribute name from the pull-down list.
If the feature was two-dimensional, it becomes three-dimensional with the specified elevation.
Note that the SurfaceDraper transformer (available in FME Professional and higher) can be used to supply interpolated elevation values to the vertices of 2D features based on a 3D grid or set of 3D features.
Transformer Categories
Search FME Community
Technical History
Associated FME function or factory: @ZValue
Tags Keywords: ElevationSetter
