Teradata Non-Spatial User Attributes
For information on the parameters in this dialog that are common to all readers, see:
For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Name The name of the field to be written.
Type
This format supports the following field types.
bigint
Represents 64-bit signed integers, in the range of 2^63+1 to 2^63-1.
blob
Represents a variable length Binary Large Object (BLOB), used to store binary data of up to 2097088000 bytes.
byte
Represents a fixed-length binary object up to a length of 64000 bytes.
byteint
Represents a 8-bit (1-byte) signed integer, in the range of 128 to 127.
char
Represents a fixed length character string. The maximum length depends on the server character set: 32000 bytes (KANJISJIS) or 32000 characters (UNICODE/GRAPHIC) or 64000 characters (LATIN).
char_unicode
Represents a fixed length character string in UNICODE. Teradata uses UTF-16 to represent UNICODE characters.
clob
Represents a variable length Character Large Object (CLOB), up to a length of 1048544000 characters for UNICODE server character set, or 2097088000 characters for LATIN server character set.
clob_unicode
Represents a variable length Character Large Object (CLOB) in UNICODE, up to a length of 1048544000 characters.
date
Represents date data from January 1, 0001 to December 31, 9999.
See Standard FME Date and Time Format.
decimal
Represents a decimal number with a fixed number of up to 38 digits.
float
Represents a 64-bit floating precision number.
int
This type is used to represent 32-bit signed integers from 2^31+1 to 2^31-1.
json
Represents text or binary JSON documents. If the storage format is text, the maximum length is 16776192 LATIN characters or 8388096 UNICODE characters. If the storage format is BSON or UBJSON, the maximum length is 16776192 bytes.
number
Represents a fixed or floating point decimal.
smallint
This type is used to represent 16-bit signed integers from -2^15+1 to 2^15-1.
time
This type is used to represent time data with an accuracy of up to 1 microsecond.
timestamp
This type is used to represent date and time data from January 1, 0001 to December 31, 9999 with an accuracy of up to 1 microsecond.
timestamptz
This type is used to represent date and time with time zone data and an accuracy of up to 1 microsecond.
timetz
This type is used to represent time with time zone data in the range of 00:00:00 to 24:00:00.
varbyte
Represents a variable-length of binary data up to a length of 64000 bytes.
varchar
Represents variable-length character data. The maximum length depends on the server character set: up to a length of 32000 bytes (KANJISJIS) or 32000 characters (UNICODE/GRAPHIC) or 64000 characters (LATIN).
varchar_unicode
Represents variable-length character data in UNICODE. Teradata uses UTF-16 to represent UNICODE characters.
xml
Represents XML content of up to 2 gigabytes.
Index
The types of indexes and constraints to create for the column.
Indexes and constraints are created only if the table is created. Each index and constraint contains only one column.
The valid values for the column type are listed below:
PrimaryIndex: Applies primary index constraint.
PrimaryIndexNotNull: Applies primary index and non-nullable constraints.
PrimaryKeyNotNull: Applies non-nullable and unique constraints on a column that is used as a primary key for the table. Only one primary key is allowed per table.
UniqueNotNull: Applies non-nullable and unique constraints.
NotNull: Applies non-nullable constraint.
