Esri Geodatabase Geometry Support
See Also
Geometry
Supported?
Notes
Aggregates (IFMEAggregate) No
Arcs (IFMEArc)
Yes
Boxes (IFMEBox) Yes
BRep Solids (IFMEBRepSolid) No Accepts, but converts into MultiSurface.
Clothoids (IFMEClothoid)
Yes
Composite Solids (IFMECompositeSolid) No Accepts, but converts into MultiSurface.
Composite Surfaces (IFMECompositeSurface) No Accepts, but converts into MultiSurface.
Coordinate Precision Full (32-bit)
CSG Solids (IFMECSGSolid) No Accepts, but converts into MultiSurface.
Donuts (IFMEDonut)
Yes
Ellipses (IFMEEllipse)
Yes
Extrusions (IFMEExtrusion) No Accepts, but converts into MultiSurface.
Faces (IFMEFace) Yes
Feature Table/Bulk Mode Processing (IFMEFeatureTable) No
Geometry Definitions and Instances No
Georeferencing Native
Hierarchical Geometries No
Homogeneous Aggregates No
Lines (IFMELIne)
Yes
Measures Yes
Meshes (IFMEMesh) Yes
MultiArea (IFMEMultiArea)
Yes
MultiCurve (IFMEMultiCurve)
Yes
Multiple Geometries No
MultiPoint (IFMEMultiPoint)
Yes
MultiSolid (IFMEMultiSolid) No Accepts, but converts into MultiSurface.
MultiSurface (IFMEMultiSurface) Yes
MultiText (IFMEMultiText)
No
Nulls (IFMENull)
Yes
Oriented Arcs (IFMEOrientedArc)
Yes
Paths (IFMEPath)
Yes
Point Clouds (IFMEPointCloud) No
Points (IFMEPoint)
Yes
Polygons (IFMEPolygon)
Yes
Rasters (IFMERaster) Yes
Rectangle Faces (IFMERectangleFace) No Accepts, but converts into face.
Surface Normals Yes
Surface Sidedness Single-sided
Text (IFMEText)
Yes
Textures Yes
Traits No
Triangle Fans (IFMETriangleFan) Yes
Triangle Strips (IFMETriangleStrip) Yes
Z values Yes
