Calculates the length of strings and the number of bytes in a blob.
After connecting the transformer, select the source attribute from the list.
This attribute contains the resulting value.
Note that in non-ASCII character sets, the length is the number of actual characters (some or all of which could be multi-byte) in the string, which may not match the number of bytes used to store the string.
To calculate the number of bytes in a blob:
Locate the _length attribute name in the Information Window:
Associated FME function or factory: @Tcl2
