Identifies a value to act as a nodata identifier on a raster feature at the band level. That is, values equal to the specified value will now be considered invalid, and will not be affected by many operations (for example, offsetting or scaling).
All selected bands on an input raster feature will receive the same specified nodata value.
Input features must contain raster geometries only.
A numeric value specifying the nodata value to be set on the input raster. This parameter sets the nodata value and discards the original nodata value if it exists.
If the raster's bands have palettes, the function will succeed in setting a new nodata value only if the value is of a key that already exists on the band. To replace all occurrences of the original nodata value with a new value, use the RasterCellValueReplacer.
If No, no cell values in the raster are changed. If Yes, cells that used to be equal to the old nodata value are changed to the new nodata value.
For example, consider a raster with values [1 2 3], in which the nodata value is initially 1 and we are setting it to 2.
If this option is No, the raster will still have values [1 2 3], and 2 is the new nodata value. That is, the cell with a value of 1 that previously was nodata is now a valid value.
If this option is set to Yes, the raster will have values [2 2 3] , and 2 is the new nodata value. That is, the cell with a value of 1 that previously was nodata is still nodata, but now has a different raw value.
Associated FME function or factory: @RasterNodata
Tags Keywords: raster grid band channel palette key lookup LUT colormap colourmap nodata null void value set modify flag
