Licensing from the Linux Command Line
To activate a single-fixed license with your serial number
- Run:
./fmelicensingassistant --serial <serial-number>
To get your serial number, see the confirmation e-mail you received after purchasing FME Desktop.
To activate a single-fixed license with a trial code
- Visit http://www.safe.com/evaluation/index.php
- Run:
./fmelicensingassistant --trial <trial-license-code>
To activate a license file provided by Safe Software
- Complete steps 1-3 under Installing a License File Provided by Safe Software.
- Run:
Note: To obtain the registration key, navigate to the FME Desktop installation folder and run:
./fmelicensingassistant --key
./fmelicensingassistant --file <filename>
To configure FME Desktop to use a floating license
- Complete steps 1-5 under Installing a Floating License on Linux.
- Run:
./fmelicensingassistant --floating <server>[:<port>] <FME-Edition>
Note: For information about specifying <FME-Edition>, see Specifying the FME Edition to Use.
To configure FME Desktop to use a three-server redundant floating license
- Complete steps 1-3 under Installing a Three-Server Redundant Floating License Server on Linux
- Run:
./fmelicensingassistant --floating <master-node-server>[:<port>] <FME-Edition>
