You are here: Administrator's Guide > Installation Options
The FME Server installer provides three options for installation: Express, Distributed, and Engine.
Express
The Express option installs all required components, and is the easiest way to install FME Server.
When to Choose the Express Install
Use the Express installation if you are not concerned about planning for n-tier architecture or fault tolerance. You want to get started quickly with a single installation of FME Server.
Distributed
The Distributed Installation option provides flexibility over which components to install yourself and which are installed automatically.
When to Choose the Distributed Install
Use the Distributed installation for any of these scenarios:
Engine
The Engine installation allows you to build onto a current FME Server installation by Adding FME Engines on a Separate Machine for fault tolerance and/or high capacity.
