Daylight Savings Time
FME’s performance is not affected in any way by changes in local time zones related to daylight savings, or by extensions to the number of weeks of daylight savings time, as long as your computer’s clock has been set to automatically adjust for daylight saving changes.
If you are running FME on a Windows operating system, you can ensure that this option is already set by opening the Control Panel, selecting Date and Time options, then selecting the Time Zone tab.
