You are here: Working with FME Desktop > Working with FME Server > Publishing to FME Server > Upload Connections
Upload Connections
If your workspace contains any database or web connections, use the Upload Connections dialog to specify the connections you want to upload. Unless previously uploaded, you must upload any connections you want to reference when the workspace runs from FME Server.
Check the box for each connection you want to upload.
Click Next to proceed to Register Services.
