You are here: Working with FME Desktop > Working with Coordinate Systems > Defining Custom Units
FME defines a large number of units (for example, meters, US feet, degrees, radians, etc.).  If your coordinate system is measured in a unit that FME does not already know about, you can define the new unit.
Unit definitions may occur in an FME mapping file, as well as in the file:
LocalCoordSysDefs.fme
The syntax of a unit definition is:
UNIT_DEF <unit name> \
    UNIT_TYPE <unit type> \
    UNIT_ABBREVIATION <unit abbreviation> \
    UNIT_FACTOR <unit size>
Name
Range
Description
Optional
<unit name>
any string
The name of the unit being defined.
No
<unit type>
ANGLE | LENGTH
Specifies whether the unit measures angles or lengths.
No
<unit abbreviation>
any string
This abbreviation represents the unit and may be used in coordinate system definitions instead of the <unitname>.
No
<unit size>
Floating point number
The size of a unit in metres if it measures length. If the unit measures angle, then this is the size in degrees.
No
Example Unit Definition
In this example, we define the unit “GRIDUNIT” (abbreviated as “GRD”) where the unit length is 0.999738 meters.
UNIT_DEF GRIDUNIT  \
    UNIT_TYPE LENGTH  \
    UNIT_ABBREVIATION GRD   \
    UNIT_FACTOR 0.999738
