Date/Time Functions
Use the following functions to parse, format, and manipulate date, time, and datetime values anywhere in FME where expressions are supported. Unless stated otherwise, temporal arguments (date, time, datetime) must be in Standard FME Date/Time Format. For arithmetic support, see also DateTimeCalculator in the FME Workbench Transformers help.
Note: String arguments in date/time functions are automatically trimmed of leading and trailing whitespaces.
When a temporal arguments is processed, if the year, month, day, hours, minutes, and/or seconds are outside the supported range, the argument is rejected and the result is set to null. @DateTimeParse is the only date/time function that has an optional argument to repair parts that overflow supported ranges (except for years). For example, @DateTimeParse(20161332,%Y%m%d,repair) will repair the input date to 20170201.
Tip: Use @DateTimeParse to repair leap seconds and other temporal values containing parts that overflow supported ranges, such as datetime values generated by sensors and other mechanical devices.
Summary of Date/Time Functions
Function Description Examples
@DateTimeAdd() Datetime + Interval = Datetime
@DateTimeAdd(20170102, P1M) = 20170202
@DateTimeAdd(20170102, -P1M) = 20161202
@DateTimeCast()
Casts source type to destination type, if conversion is safe.
@DateTimeCast(20170102123000-08, time) = 123000-08:00
@DateTimeCast(20170132, date) = null
@DateTimeCast(20170001, date) = null
@DateTimeCreate() Creates datetime strings, unzoned or with UTC offset. @DateTimeCreate(2017,1,2,12,30,0,-08) = 20170102123000-08:00
@DateTimeDiff() Datetime – Datetime = Interval
@DateTimeDiff(20170201,20170101) = P1M
@DateTimeDiff(20170202, 20170201, seconds) = 86400
@DateTimeFormat() Formats FME datetime strings for consumption by writers and transformers. @DateTimeFormat(20170102,%B %d %Y) = January 02 2017
@DateTimeIntervalCreate() Creates interval strings in ISO 8601 duration format. @DateTimeIntervalCreate(1,0,0,0,0,0) = P1Y
@DateTimeIntervalNegate() Negates intervals. @DateTimeIntervalNegate(P1Y) = -P1Y
@DateTimeNow() Creates timestamps in local, local unzoned, or UTC time.
@DateTimeNow() = 20170203170000.1234567
@DateTimeNow(localUnzoned) = 20170203170000.1234567
@DateTimeNow(local) = 20170203170000.1234567-08:00
@DateTimeNow(utc) = 20170204010000.1234567+00:00
@DateTimeParse()
Parses arbitrary strings containing date time information into datetime strings in FME format.
Can be used for validation and repair. Can parse leap seconds by carrying the extra second forward so that all parts are brought in range.
@DateTimeParse(January 2 2017, %B %d %Y) = 20170102
@DateTimeParse(20170229,%Y%m%d,repair) = 20170301
@TimeZoneGet Retrieves the UTC offset of zoned datetime values. @TimeZoneGet(083000-08) = -08:00
@TimeZoneRemove Removes the UTC offset of zoned datetime values. @TimeZoneRemove(083000-08) = 083000
@TimeZoneSet Sets a time zone (UTC offset) onto an unzoned datetime, or converts a zoned datetime into another time zone.
@TimeZoneSet(083000-01:00, -08:00) = 013000-08:00
@TimeZoneSet(083000, -08:00) = 083000-08:00
@TimeZoneSet(083000-01:00, local) = 013000-08:00
@TimeZoneSet(083000-01:00, utc) = 093000+00:00
Detailed Date/Time Function Descriptions
Date/Time Construction Functions
Date/Time Arithmetic Functions
Date/Time Time Zone Functions
Date/Time Parse/Format Functions
Format String Flags and Examples
Type Flag Meaning @DateTimeParse @DateTimeFormat
Year %Y Four-digit year, with range 1000 to 9999. @DateTimeParse(2017-01-02, %Y-%m-%d) = 20170102 @DateTimeFormat(20170102, %Y-%m-%d) = 2017-01-02
%y Two-digit year. Not supported. @DateTimeFormat(20170102, %y-%m-%d) = 17-01-02
Month %m Two-digit month, with range 01 to 12.
One digit month accepted if separated by delimiters.
@DateTimeParse(2017-1-2, %Y-%m-%d) = 20170102
%N Same as %m except as noted. @DateTimeParse(1/2/2017,%N/%e/%Y) = 20170102
Same as %m, except leading zeros are removed.
@DateTimeFormat(20170102,%N/%e/%Y) = 1/2/2017
%b Abbreviated, 3-letter English month name. @DateTimeParse(Jan 2 2017,%b %d %Y) = 20170102 @DateTimeFormat(20170102, %b %d %Y) = Jan 02 2017
%B   @DateTimeParse(January 2 2017,%B %d %Y) = 20170102 @DateTimeFormat(20170102, %B %d %Y) = January 02 2017
Week %a Abbreviated, 3-letter weekday names. Not supported. Consider parsing using *. @DateTimeFormat(20170102, %a %b %d %Y) = Mon Jan 02 2017
%A Full weekday names. Not supported. Consider parsing using *. @DateTimeFormat(20170102, %A %B %d %Y) = Monday January 02 2017
%u Single digit day of week, with range 1 to 7, Monday being 1. Not supported. @DateTimeFormat(20170102, %u) = 1
%U Two digit week of year, with range 00 to 53, starting with the first Sunday as the first day of week 01. Not supported.
@DateTimeFormat(20160102, %U) = 00
@DateTimeFormat(20160103, %U) = 01
@DateTimeFormat(20171231, %U) = 53
%w Single digit day of week, with range 0 to 6, Sunday being 0. Not supported. @DateTimeFormat(20170101, %w) = 0
%W Two digit week of year, with range 00 to 53, starting with the first Monday as the first day of week 01. Not supported.
@DateTimeFormat(20160103, %W) = 00
@DateTimeFormat(20160104, %W) = 01
@DateTimeFormat(20181231, %W) = 53
Day %d Two-digit day of month, with range 01 to the last day of the month.
One digit day accepted if separated by delimiters.
%e Same as %d except as noted. @DateTimeParse(1/2/2017,%N/%e/%Y) = 20170102
Same as %d, except leading zeros are removed.
%j Three-digit day of year, with range from 001 to 365 (non-leap year) or 366 (leap year).
One and two digit days of year accepted.
@DateTimeParse(20171,%Y%j) = 20170101
@DateTimeFormat(20170101,%Y-%j) = 2017-001
@DateTimeFormat(20161231,%Y-%j) = 2016-366
Hours %H Two-digit hours, with range from 00 to 23.
One digit hours value accepted if separated by delimiters.
@DateTimeParse(8:30, %H:%M) = 083000
@DateTimeFormat(083000, %H:%M:%S) = 08:30:00
%k Same as %H except as noted. @DateTimeParse(8:30, %k:%M) = 083000
Same as %H, except leading zeros are removed.
@DateTimeFormat(083000, %k:%M%p) = 8:30AM
%I (i) 12-hour clock, with range 01 to 12.
@DateTimeParse(8:30PM, %I:%M%p) = 203000
@DateTimeFormat(203000, %I:%M %p) = 08:30PM
%I (L) Same as %I, except as noted. @DateTimeParse(8:30PM, %l:%M%p) = 203000
Same as %I, except leading zeros are removed.
@DateTimeFormat(203000, %l:%M%p) = 8:30PM
%p AM/PM
AM/PM accepted, case insensitive.
@DateTimeParse(12:30am, %I:%M%p) = 003000
@DateTimeFormat(083000, %I:%M %p) = 08:30 AM
Minutes %M Two-digit minutes, with range 00 to 59.
One digit minutes value accepted if separated by delimiters.
Seconds %S Two-digit seconds, with range 00 to 59. Fractional seconds are supported up to nanosecond resolution.
One digit seconds value accepted if separated by delimiters.
@DateTimeParse(8:30:01.234, %H:%M:%S) = 083001.234
@DateTimeFormat(083059.123, %H:%M:%S) = 08:30:59.123
%s
Seconds since the Unix Epoch time (1970-01-01 00:00:00+00:00). Fractional seconds are supported up to nanosecond resolution.
Format string is rejected if both %z and %s are present.
Accepts epoch time. Outputs UTC datetime.
The seconds part must have at least a single digit. For example, "0.1" is considered a valid value for %s, but ".1" is not.
@DateTimeParse(1.234, %s) = 19700101000001.234+00:00
@DateTimeParse(1.234-08:00, %s%z) = null
Accepts zoned datetime. Outputs epoch time.
@DateTimeFormat( 19700101000001.234+00:00, %s) = 1.123
@DateTimeFormat( 19700101000001.234, %s) = null
@DateTimeFormat( 19700101000001.234+00:00, %s%z) = null
%Es
Same as %s, except this flag supports unzoned dates and datetimes.
Format string is rejected if both %z and %Es are present.
Accepts epoch time. Outputs UTC datetime, but with the UTC offset removed. So output is unzoned.
@DateTimeParse(1.234, %Es) = 19700101000001.234
@DateTimeParse(1.234, %Es%z) = null
Accepts unzoned date or datetime and treats it as UTC time. Outputs epoch time.
@DateTimeFormat( 19700101000001.234, %Es) = 1.234
@DateTimeFormat(19700102, %Es) = 86400
@DateTimeFormat( 19700101000001.234+00:00, %Es) = null
@DateTimeFormat(19700101000001.234, %Es%z) = null
Time Zone %z UTC offset in the form +/-hh:mm, except as noted.
UTC offset in the form +/-hh, +/-hhmm, or +/-hh:mm, or Z for Zulu time which is +00:00.
@DateTimeParse(8:30-08,%H:%M%z) = 083000-08:00
@DateTimeFormat(000000-08:00,%T%z) = 00:00:00-08:00
%Ez Same as %z, except as noted. @DateTimeParse(03:04:05Z,%H:%M:%S%Ez) = 030405+00:00
Same as %Ez, except +00:00 is output as Z for Zulu time.
@DateTimeFormat(030405+00:00,%T%Ez)=03:04:05Z
Shortcuts %T Equal to %H:%M:%S @DateTimeParse(03:04:05,%T) = 030405 @DateTimeFormat(000000,%T) = 00:00:00
FME
Auto parses input that is in the Standard FME Date/Time Format, and repairs overflow parts if the repair argument is set.
Specifically, @DateTimeParse() looks for the following matches:
  • %Y%m%d$
  • %H%M%S$
  • %H%M%S%Ez$
  • %Y%m%d%H%M%S$
  • %Y%m%d%H%M%S%Ez$
It can be combined with the flag ISO, separated by the | character.
To disambiguate this shortcut from a regular text string of the same content, when FME and ISO are specified, there must be no other format flags present.
@DateTimeParse(030460-0800, FME, repair) = 030500-08:00
@DateTimeParse(030460-0800, FME|ISO, repair) = 030500-08:00
@DateTimeFormat(083000-08, FME) = 083000-08:00
@DateTimeFormat(20170229, FME) = null
ISO
Auto parses/formats input into ISO datetime format.
  • %Y-%m-%d$
  • %H:%M:%S$
  • %H:%M:%S%Ez$
  • %Y-%m-%dT%H:%M:%S$
  • %Y-%m-%dT%H:%M:%S%Ez$
To disambiguate this shortcut from a regular text string of the same content, when ISO is specified, there must be no other format flags present.
@DateTimeParse(2017-01-02, FME | ISO) = 20170102
@DateTimeParse(03:04:60,ISO,repair) = 030500
@DateTimeFormat(20170102, ISO) = 2017-01-02
@DateTimeFormat(20170102030405-08,ISO) = 2017-01-02T03:04:05-08:00
Wildcard Character *
A single word, which matches a sequence of characters delimited either by whitespaces, the end of string, or the character immediately following the * character.
For example, "Monday," can be parsed by either "*" or "*,".
The following are special characters that might follow the * wildcard and what they mean:
Sequence Description
** Reject input.
*? Reject input.
*$ $ is treated as end of string.
*% Keep parsing. All % flags except below are rejected.
Word that ends with %
*%* Word that ends with *
*%? Word that ends with ?
*%$ Word that ends with $
@DateTimeParse("On Monday, January 23 2017","* * %B %d %Y") = 20170123
@DateTimeParse("On Monday, January 23 2017","* *, %B %d %Y") = 20170123
Not supported.
? A single character.
@DateTimeParse(January 23rd 2017,%B %d?? %Y) = 20170123
@DateTimeParse(LC80460262015110LGN00, LC???????%Y%jLGN??) = 20150420
Not supported.
End of input string. Used to ensure that the input fully matches the format string.
Note: Input strings are auto-trimmed of trailing whitespaces.
@DateTimeParse(2017-01-02, %Y-%m-%d$) = 20170102
@DateTimeParse(2017-01-02 and then, %Y-%m-%d$) = null
Not supported.
Special Character %% The % character. @DateTimeParse(2017%01%05,%Y%%%m%%%d) = 20170105 @DateTimeFormat(020304,%T %%) = 02:03:04 %
%* The * character. @DateTimeParse(*** 2017-01-05,%*%*%* %Y-%m-%d) = 20170105 Not supported.
%? The ? character. @DateTimeParse(On Jan 2 2017?,* %b %d %Y%?) = 20170102 Not supported.
%$ The $ character. @DateTimeParse(2017$01$02,%Y%$%m%$%d) = 20170102 Not supported.
Regular Character Any Any character that is not a wildcard or special character as documented above is considered a regular character. Case sensitivity is respected.
@DateTimeParse(On Jan 23 2017, On %b %d %Y) = 20170123
@DateTimeParse(On Jan 23 2017, on %b %d %Y) = null
@DateTimeFormat(20170102,On %B %d %Y) = On January 02 2017
See Also
DateTimeCalculator
DateTimeConverter
DateTimeStamper
