RDB_Project Quick Facts
| Format Type Identifier | RDB_PROJECT |
| Reader/Writer | Reader |
| Licensing Level | Professional |
| Dependencies | RDB, XML |
| Dataset Type | File |
| Feature Type | RDB_PROJECT |
| Typical File Extensions | .rpp, .rsp |
| Automated Translation Support | Yes |
| User-Defined Attributes | No |
| Coordinate System Support | No |
| Generic Color Support | No |
| Spatial Index | No |
| Schema Required | Yes |
| Transaction Support | No |
| Encoding Support | No |
| Geometry Type | fme_type |
| Geometry Support | ||||
| Geometry | Supported? | Geometry | Supported? | |
| aggregate | no | point | no | |
| circles | no | polygon | no | |
| circular arc | no | raster | no | |
| donut polygon | no | solid | no | |
| elliptical arc | no | surface | no | |
| ellipses | no | text | no | |
| line | no | z values | yes | |
| None | no | point cloud | yes | |
| Point Cloud Component | Data Type | Notes |
| fmepc_angle | INT8 | ScanAngleRank (-128..127) in degrees. Only in P3D.rds version 3.0. |
| fmepc_classification | UINT8 | Classification from LAS Standard 1.3. Only in P3D.rds version 1.1+. |
| fmepc_color_r | UINT8 | From optional RGB file |
| fmepc_color_g | UINT8 | From optional RGB file |
| fmepc_color_b | UINT8 | From optional RGB file |
| fmepc_flight_line_edge | not supported | |
| fmepc_flight_line | not supported | |
| fmepc_gps_timeUINT64 | UINT64 | Timestamp. Retrieved either from data file or optional TST file |
| fmepc_gps_week | not supported | |
| fmepc_intensity | INT16 | Reflectance or amplitude |
| fmepc_number_of_returns | UINT8 | TargetCount. Only in P3D.rds version 2.2, 3.0. |
| fmepc_point_source_id | UINT32 | SourceIndex. Only in P3D.rds version 2.1, 2.2, 3.0. |
| fmepc_posix_time | not supported | |
| fmepc_return | UINT8 | TargetNumber. Only in P3D.rds version 2.2, 3.0. |
| fmepc_scan_direction | not supported | |
| fmepc_user_data | not supported |
