MariaDB (MySQL-compatible) Non-Spatial Writer: User Attributes
For information on the parameters in this dialog that are common to all readers, see:
For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
| Name |
The name of the field to be written. Valid values for field name include any character string devoid of SQL-offensive characters and less than 63 characters in length. |
| Type |
The type of a column in a table. The valid values for the field type are listed below: bigint blob char date datetime decimal double double(width,decimal) enum float float(width,decimal) int longblob longtext mediumblob mediumint mediumtext set smallint text time timestamp tinyblob tinyint tinytext varchar year year(width) |
| Index |
The type of index to create for the column. The valid values for the index type are listed below:
