JDBC Writer Parameters
| Database Connections |
Connections store authentication information. For general information about sharing database connections, please see Using Database Connections. Note that different subsets of Database Connection parameters are made available in different contexts. Select an existing connection, or Add Database Connection to define a new connection. The new connection can be made visible only to the current user, or can be shared among multiple users. |
Connection Parameters
The connection string for the database to which you are connecting. The precise format depends on the JDBC driver being used, but a connection string will always start with:
jdbc:<subprotocol>:
See the FME Knowledge Center for information about the compatibility of various JDBC drivers with FME, and to view Workbench examples.
If not specified in the JDBC Connection String, enter the username and password to access the database.
This parameter is not required for well-behaved JDBC 4.0+ drivers.
For drivers that do not self-register, enter the name of the Java class for the driver desired.
Note: When errors are being returned by the wrong JDBC driver, specifying the Driver Class can force the connection string to be processed by only the desired driver.
Advanced Settings
The number of features that FME places in each transaction before a transaction is committed to the database.
This parameter defines the time, in seconds, after which a query will be terminated if it has not yet returned a result.
If set to zero, there is no timeout.
