Google Fusion Tables (Spatial) Writer: Feature Type Parameters
To access feature type parameters, click the gear icon on a feature type in the workspace to open the Feature Type Parameter Editor. To always display the editor in Workbench, you can select View > Windows > Parameter Editor.
General
All feature types share similar General parameters, including the Feature Type Name, Reader or Writer Name, and Geometry.
In most Writer Feature Type parameter dialogs, you can also control Dynamic Schema Definitions. Some database formats accept a Table Qualifier prefix on the output table feature type.
See Editing Writer Feature Types for more information.
Table Settings
This parameter determines settings at the feature type level.
- INSERT: Allows for only INSERT operations.
- UPDATE and DELETE: These writer modes can be overwritten at feature type levels.
- INHERIT_FROM_WRITER: Use the value at the writer level as the default for features contained in the table.
If the table exists by this name, it should be dropped and recreated before any features are written to it. This option is only valid when creating a new table.
If the table exists by this name, it should be truncated before any features are written to it. This option will result in an empty table if combined with UPDATE or DELETE mode.
Advanced
A comma-separated list of the columns that are matched against the corresponding FME attribute’s values. The list specifies which rows are to be updated or deleted when the writer mode is either UPDATE or DELETE.
