Feature Types and User Attributes
Fixed Schema
The user attributes for this format come from the schema; they are visible in the Feature Type > User Attributes tab, but you cannot modify them.
waypoints
Geometry type: fme_point
Feature Attribute | Description |
name |
Name of the point of interest. If empty or not provided, a default value of WPTxxx is assigned, where xxx is an auto-incrementing number. |
desc |
Description of the point of interest. If empty or not provided, the name value is used. |
