Menu Commands and Shortcuts
See also Workbench Keyboard Shortcuts for an additional list of shortcuts.
File
| Command | Keyboard Shortcut | Function |
| New | Ctrl+n | Opens the Create Workspace dialog, which provides different options for creating a new workspace. |
| Open | Ctrl+o | Opens a file browser so you can pick an FME workspace (.fmw) file. |
| Generate Workspace | Ctrl+g | Opens the Generate Workspace dialog. |
| Open Recent/Open Recent Template | Opens a recently-opened workspace or workspace template. | |
| Close | Ctrl+w | Closes the current workspace. |
| Save | Ctrl+s | Saves the current workspace. |
| Save As | Saves the current workspace to a different name. You can also save a simple workspace to a mapping file (.fme) for use with the FME Quick Translator. |
| Save As Template | Saves the current workspace as a template (.fmwt). | |
| Export as Custom Transformer | Exports the workspace as a custom transformer. | |
| Export As Custom Format | Exports the workspace as a custom transformer. | |
| Publish/Republish to FME Server | Publishes a workspace to an FME Server. Note that you must have an FME Server configured as part of your system. | |
| Download from FME Server | Downloads a workspace from an FME Server. Note that you must have an FME Server configured as part of your system. | |
Previews and prints the workspace. Tip: To print only a portion of a workspace, click and drag to select items on the canvas before previewing. To preview and print the entire workspace, toggle the Print Selected Only icon on the Print Preview toolbar. To fit a large workspace (or selection) to one page, select the Fit to Page icon. |
| Send To | Opens your e-mail client with the current workspace attached to a new e-mail. | |
| Exit | Ctrl+q | Quits Workbench. |
Edit
| Undo | Ctrl+z | Reverses the most recent action in a workspace. |
| Redo | Ctrl+y | Repeats the most recent action that you reversed in a workspace. |
| Cut | Ctrl+x | Cuts a selection and sends it to the clipboard. |
| Copy | Ctrl+c | Copies a selection and sends it to the clipboard. |
| Paste | Ctrl+v | Pastes a selection from the clipboard. |
| Delete | Del (key) | Deletes a selection. |
| Bring to Front/Send to Back | Brings objects forward on the canvas or sends them behind other objects. | |
| Align Horizontally/Vertically | Aligns selected objects on the canvas with one another, according to the specified orientation. | |
| Spread | Evenly spaces selected objects on the canvas from one another, either horizontally vertically. | |
| Select All | Ctrl+a | Selects all content on the canvas. |
View
| Windows | Shows/hides various Workbench windows. | |
| Expand All/Collapse All | Expands/collapses all workspace objects. | |
| View Attached Annotations | Shows/hides annotations defined by the user. | |
| View Summary Annotations | Shows/hides summary annotations, which display a box that contains information about the feature type or transformer. | |
| Zoom |
Sets default zoom properties. Locate the corresponding tool Zoom Mini-bar in FME > Options > Toolbar.
The tool has a slider, +/- buttons, and a text entry box so you can enter a zoom value. It also includes a "zoom to extents" button to fit the workspace into the available canvas area. |
Tags grids |
Displays the Grid and Guides dialog:
| Connection Style | Ctrl+Shift+c | Changes the appearance of connections on the Workbench canvas between Curved, Squared, and Straight. |
| Maximize Canvas | Shift+F11 | Maximizes the canvas to the size of the current window. |
| Full Screen | F11 | Maximizes the canvas to the size of the screen. |
Readers
| Add Reader | Ctrl+Alt+r | Adds a reader to the workspace. |
| Import Feature Types | Imports feature types from a different dataset. | |
| Update Feature Types |
Updates feature types if the structure of the data has changed outside the workspace. |
| Enable/Disable Feature Types | Temporarily disables (or enables) feature types in the workspace. | |
| Remove Feature Types | Removes the specified feature types. | |
| Remove Readers | Removes the specified readers. | |
| Add Reader as Resource | Inserts a reference to a dataset to be used in the workspace. |
Transformers
| Add Transformer | / (key) | Opens a search bar for adding a transformer to the canvas. |
| Remove Transformers | Removes the specified transformers from the workspace. | |
| Enable/Disable Transformers | Disables (or enables) transformers in the workspace. | |
| Enable/Disable Inspectors | Disables (or enables) any Inspectors in the workspace. | |
| Create Custom Transformer | Ctrl+t | Adds a custom transformer to the workspace. |
| Embed All Transformers | Changes the status of any linked custom transformers in the workspace to embedded. |
Writers
| Add Writer | Ctrl+Alt+w | Adds a writer to the workspace. |
| Add Feature Type | Adds a new feature type to the workspace. | |
| Import Feature Type | Imports a feature type from a different dataset. | |
| Update Feature Types | Updates feature types if the structure of the data has changed outside the workspace. | |
| Remove Feature Types | Removes a feature type. | |
| Remove Writers | Removes the specified writer. | |
| Move Feature Types | Moves feature types between datasets. | |
| Redirect to FME Data Inspector | Redirects the output to the FME Data Inspector. |
Run
| Run Workspace | F5 | Runs the workspace with existing parameters. |
| Run With Prompt | Ctrl+r | Runs the workspace and prompts you to change parameters (for example, if you want to use different source data). |
| Run With Full Inspection | Shift+F5 | Runs the workspace in inspection mode. All links and ports display feature counts. |
| Run With Breakpoints | Ctrl+Shift+F5 | Runs the translation using the Feature Inspector, after you define a breakpoint. |
| Batch Deploy | Runs the translation in batch mode. |
Tools
| Remove |
Removes any of the following from the workspace: A list of the selected items that are in the workspace appears. For large lists, use the search filter to display. Use the checkboxes to delete the desired objects, and click OK. |
| Edit Parameters | Displays all reader and writer parameters in a dialog. This is useful especially if you have a large workspace or multiple readers/writers. | |
| Edit Header | Allows you to add format directives into the workspace (Advanced user task) | |
| Apply Auto-Layout | Optimizes the layout of objects on the Workbench canvas. | |
| Purge Temporary Files | Purge temporary Workbench-related files. | |
| Browse Coordinate Systems | Opens the Coordinate System Gallery. | |
| Browse Geographic Transformations | Opens the Geographic Transformation Gallery. | |
| Browse Readers and Writers | Opens the Reader and Writer (supported formats) Gallery. | |
| License Borrowing | Allows floating license holders to temporarily use another floating license. | |
| FME Options | Sets default options. |
