You are here: Working with FME Desktop > Working with FME Server > User and Role-based Transformations
When a job is submitted to FME Server, user and role information is passed to the workspace as published parameters. This means that it’s possible to create workspaces that do different things based on the User’s username.
The published parameter named FME_SECURITY_USER
contains the username that ran
the workspace and the published parameter named FME_SECURITY_ROLES
contains
the user’s role(s).
These parameters can be fetched with the FME ParameterFetcher transformer.
