You are here: Working with FME Desktop > Working with Databases and Web Services > Using Web Connections
Many processes in FME Desktop require you to connect and authenticate to a web service in order to use them. For example, when you use an HTTPCaller transformer, you may need to authenticate to a web service, such as Google Fusion Tables. Similarly, if you want to connect to an FME Server, you must specify a set of connection parameters. Web connections provide a convenient and secure way to store and reuse these connection parameters. Each time you need to specify the same connection parameters, you can use the connection, rather than re-entering the parameters. If the connection parameters change, you can edit them in one place, rather than in each workspace that uses the connection.
FME Desktop must be registered to use the web services to which you want to connect. Fortunately, many of the most common web services are already registered in FME. Under FME Options: Web Connections (Tools > FME Options > Web Connections), you can specify your connection parameters to these services, as well as edit them or remove them altogether. It is usually more convenient to add a web connection at the time you are using one in a workspace. However, you can also add a web connection in Web Connections, and use it later in a workspace.
To Use a Web Connection in a Workspace
You can use an existing web connection, or define a new one, in a Transformer Parameters, Add Reader, or Add Writer dialog, as well as in the Publish to FME Server wizard.
In the Edit Web Connection dialog, specify the web service, a name for the connection, and the connection parameters. If the web service uses the OAuth standard, click Authenticate and validate your connection directly with the web service.
Visibility: This field applies only if Connection Storage, as specified in Tools > FME Options > Default Paths, is a shared location visible to multiple users. Specify whether the connection is available only to yourself, or to any user of the database (Public). For more information, click Help from the Default Paths window under Tools > FME Options.
Note: The following characters are not allowed in connection names: ^ \ / : * ? " < > | & = ' + % #
Reusing a Web Connection
Note: If you did not create a connection, it may not be available for you to use unless its visibility is updated. For more information, see To change the visibility of a web connection.
  • Change the connection parameters.
  • Change a web connection to one that exposes the connection parameters in the workspace.
  • Change a connection whose parameters are exposed in the workspace to a web connection.
See Also
