Creates a series of image tiles that can be utilized by web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. This is done by resampling rasters to various different resolutions and then splitting them into tiles.
Features with raster geometry.
The resulting image tiles.
Specifies a method for tiling up data. This controls factors like the coordinate system, tile size, spacing, etc. See the Tile Schemes section for more details.
These parameters specify the zoom levels for which tiles will be generated. The exact meaning of a zoom level depends on the tile scheme, but in general a higher zoom level uses more pixels to cover the same area (i.e. more tiles will be generated).
If Minimum Zoom Level is unspecified, the minimum zoom level will default to the minimum level at which the raster is visible. Note that tiles will not be generated if the input raster covers less than 1 row and 1 column at a particular zoom level, regardless of the minimum zoom level value.
If Maximum Zoom Level is unspecified, the maximum zoom level will be the smallest zoom level such that the resampled raster has more rows or columns than the original raster.
These parameters specify the size of each output tile for tile schemes that support user-defined sizes.
Cell values are interpolated in order to change the raster to the specified size. You can choose from these interpolation methods.
If specified, an attribute will be added to each output feature specifying the quadkey for that tile. Quadkeys are used by Bing Maps to uniquely identify a single tile at a particular level of detail. Note that this attribute will only be created for quad-tree based tile schemes (GoogleMapsCompatible and GoogleCRS84Quad).
If specified, an attribute will be added to each output feature specifying the zoom level of that tile.
If specified, an attribute will be added to each output feature specifying the column of that tile.
If specified, an attribute will be added to each output feature specifying the row of that tile.
If specified, an attribute will be added to each output feature that identifies which raster it was created from. This index is zero-based, so all tiles created from the first input raster will have a value of 0, all tiles created from the second input raster will have a value of 1, etc.
If specified, an attribute will be added to each output feature identifying the total number of tiles created from the input raster, across all zoom levels.
This scheme is used by Google Maps, Bing Maps, Web Map Tile Service, and ArcGIS.
GoogleMapsCompatible zoom level 0 tiles (column, row):
GoogleMapsCompatible zoom level 1 tiles:
GoogleMapsCompatible zoom level 3 tiles:
This scheme is used by Web Map Tile Service.
Level | Spacing (degrees) |
0 | 1.25764139776733 |
1 | 0.628820698883665 |
2 | 0.251528279553466 |
3 | 0.125764139776733 |
4 | 6.28820698883665e-2 |
5 | 2.51528279553466e-2 |
6 | 1.25764139776733e-2 |
7 | 6.28820698883665e-3 |
8 | 2.51528279553466e-3 |
9 | 1.25764139776733e-3 |
10 | 6.28820698883665e-4 |
11 | 2.51528279553466e-4 |
12 | 1.25764139776733e-4 |
13 | 6.28820698883665e-5 |
14 | 2.51528279553466e-5 |
15 | 1.25764139776733e-5 |
16 | 6.28820698883665e-6 |
17 | 2.51528279553466e-6 |
18 | 1.25764139776733e-6 |
19 | 6.28820698883665e-7 |
20 | 2.51528279553466e-7 |
0 | 2 |
1 | 1 |
2 | 0.5 |
3 | 0.333333333333333 |
4 | 0.166666666666667 |
5 | 8.333333333333333e-2 |
6 | 3.333333333333333e-2 |
7 | 1.666666666666667e-2 |
8 | 8.333333333333333e-3 |
9 | 4.166666666666667e-3 |
10 | 1.388888888888889e-3 |
11 | 8.333333333333333e-4 |
12 | 2.777777777777778e-4 |
13 | 1.388888888888889e-4 |
14 | 8.333333333333333e-5 |
15 | 2.777777777777778e-5 |
16 | 8.333333333333333e-6 |
17 | 2.777777777777778e-6 |
This transformer was previously named the VirtualEarthTiler.
Associated FME function or factory: WebMapTileFactory
Tags Keywords: raster grid band "virtual earth" Bing Google "web map" webmap mapcruncher pyramid clip tile subset quadkey VirtualEarthTiler
