VertexCreator
Appends coordinates to null, point, text, line, and arc geometry, or replaces existing geometry with point geometry.
If the feature turns into a closed polygon as a result of adding the point, it will be tagged as an area feature; otherwise, it will be tagged as a line or a path ending in a line for arcs. (However, if this was the first point added, it will be tagged as a point.)
Transformer Categories
Geometries
Search FME Knowledge Center
Tags Keywords: 2DPointAdder 3DPointAdder 2DPointReplacer 3DPointReplacer
Technical History
Associated FME function or factory: VertexCreatorFactory, @GeometryType
