Applies the raster rotation angle on the input raster properties to the rest of the raster properties and data values.
The expected input is a raster with a non-zero rotation angle and the expected output is a rotated raster with a rotation angle of 0.0. It is expected that the input raster properties will be modified to conform the output raster properties for a raster rotated by the given angle.
Applying a rotation angle is primarily done for compatibility with other processing and writers that cannot handle a rotation angle.
Cell values are interpolated in order to change the raster to the specified sizes.
Interpolation methods:
Associated FME function or factory: @ApplyRasterRotation
Tags Keywords: raster grid band channel rotate rotation apply "nearest neighbor" "nearest neighbour" bilinear bicubic average interpolate
