Resamples an input raster using the desired dimensions, the desired cell size in ground units, or a percentage of the size.
To resize the input raster by dimensions, select RowsColumns.
To resize the input raster by cell size, select CellSize.
To resize the input raster by percentage, select Percentage.
Enter values when RowsColumns is selected.
Enter values when CellSize is selected.
Specify a percentage. For example, if the input raster is 1000 rows by 800 columns and this is set to 50 percent, the resulting raster will be 500 rows by 400 columns.
Cell values are interpolated in order to change the raster to the specified size. You can choose from these interpolation methods.
Associated FME function or factory: @ResampleRaster
Tags Keywords: raster grid band channel reproject resample upsample downsample "nearest neighbor" "nearest neighbour" bilinear bicubic average interpolate resize
