Sets the Ground Control Points (GCP) on a raster with the specified Column (pixel), Row (line), X Coordinate, Y Coordinate and Z Coordinate.
If the raster has already set GCPs, the old GCPs will be overwritten.
This parameter indicates the coordinate system that would be effective if the Ground Control Points were applied. This is not necessarily equivalent to the coordinate system of the feature.
A string value specifying the GCP(s). Each GCP is separated with a semicolon and each value of a 5-value GCP is separated by a space.
To set a GCP
1 10 50 -20 0
1 10 50 -2.5 0; 2 4 6 8 10; 1 2 3 4 5
Associated FME function or factory: @RasterGCP
