Extracts the band and palette values from a raster at the location of each input point and sets them as attributes on the feature.
The following band and palette properties are exposed:
_band{}.value
_band{}.palette{}.value
Note: Wherever "{}" appears, there will be one instance of the attribute for each band or palette. The first will appear with {0}, the second with {1}, and so on.
Note that no attributes will be set for points outside the reference raster extents.
The points may be organized into groups with the Group By parameter, with each group of points having its own reference raster.
Note: How parallel processing works with FME: see About Parallel Processing for detailed information.
This parameter determines whether or not the transformer should perform the work across parallel processes. If it is enabled, a process will be launched for each group specified by the Group By parameter.
For example, on a quad-core machine, minimal parallelism will result in two simultaneous FME processes. Extreme parallelism on an 8-core machine would result in 16 simultaneous processes.
You can experiment with this feature and view the information in the Windows Task Manager and the Workbench Log window.
No: This is the default behavior. Processing will only occur in this transformer once all input is present.
By Group: This transformer will process input groups in order. Changes on the value of the Group By parameter on the input stream will trigger batch processing on the currently accumulating group. This will improve overall speed if groups are large/complex, but could cause undesired behavior if input groups are not truly ordered.
This parameter determines the interpolation method to be used when retrieving raster values from points.
This transformer was previously named PointOnRasterOverlayer.
Associated FME function or factory: VectorOnRasterOverlayFactory
Tags Keywords: raster band palette vector overlay point interpolate vectorization vectorisation PointOnRasterOverlayer
