Statistics are calculated and output on each point cloud feature individually. If you want to calculate point cloud statistics on a group of point clouds in aggregate, merge them prior to this transformer with the PointCloudCombiner.
Features with the calculated statistics are output through this port.
Specifies which statistics to calculate for each component.
The following statistics may be calculated:
Statistics will be stored as attributes on the feature. Attributes will be named <component>.<statistic>, where statistic is one of the following: min, max, range, mean, stdev, sum, median, mode. For example, if median was calculated for component z, then an attribute named z.median would be added to the feature.
FME Factory Used: @CalculatePointCloudStatistics
