Filters a point-cloud feature into one or more parts, output via separate ports, based on evaluating expressions.
Each point will only be filtered into a single point cloud. For example, if a point matches both the first and second expression, the point will only be placed in the point cloud for the first expression. An additional point cloud will be output that contains all the points that did not match any expression.
Note: Empty point clouds will not be output.
This transformer accepts only point-cloud features.
You can specify an output port for each expression.
Points that do not match any of the specified expressions are output via the <Unfiltered> port.
An expression describing which points to include in a point cloud. Expressions are described in detail in the PointCloudExpressionEvaluator transformer.
Specify the name of an output port for the point cloud.
Whether to output a point cloud containing all the points that did not match any expression. When these points are not needed, setting this to No will improve performance.
Associated FME function or factory: PointCloudEvaluationFactory
Tags Keywords: point "point cloud" cloud PointCloud coerce LiDAR sonar resample thin
