Deletes duplicated features. Features are considered to be duplicates if their geometries are within tolerance and only features with a smaller tolerance will remain after cleaning.
Each feature that is output through the Cleaned port will have a new attribute "mrf_clean_status" added to specify whether the feature was modified, created, or unchanged in the cleaning process. The possible values of this attribute are "Modified", "Created" and "Original".
If selected, each group of features with the same values in the Group By attributes will be processed separately from other groups.
Note: How parallel processing works with FME: see About Parallel Processing for detailed information.
This parameter determines whether or not the transformer should perform the work across parallel processes. If it is enabled, a process will be launched for each group specified by the Group By parameter.
For example, on a quad-core machine, minimal parallelism will result in two simultaneous FME processes. Extreme parallelism on an 8-core machine would result in 16 simultaneous processes.
You can experiment with this feature and view the information in the Windows Task Manager and the Workbench Log window.
No: This is the default behavior. Processing will only occur in this transformer once all input is present.
By Group: This transformer will process input groups in order. Changes on the value of the Group By parameter on the input stream will trigger batch processing on the currently accumulating group. This will improve overall speed if groups are large/complex, but could cause undesired behavior if input groups are not truly ordered.
This transformer performs the same operation as the MRF2DCleaner with the Remove Duplicate Geometries set to Yes and no other options selected. See the MRF2DCleaner for more details.1Portions of this work are the intellectual property of the MRF Geosystems Corporation and are used under license. Copyright © 2006 MRF Geosystems Corporation. All rights reserved.
Associated FME function or factory: MRFCleanFactory
