Logs each feature to the translation log. All attributes and geometry of the feature will be output.
Limits can be placed on both the number of features that will be logged, and the number of coordinates that will be logged per feature.
Features to be logged.
All logged Input features are output to this port unchanged.
You can choose to add a message to the log file, which can be useful to identify features if you have many Logger transformers. If present, this message is output to the log file before each feature is logged.
The number of coordinates to be logged. If not specified, the first 5 and the last 5 coordinates will be logged. If the feature has more than the maximum allowed coordinates, then only a set of coordinates at the beginning and end of the feature will be logged.
If you enter -1, all coordinates will be logged; if you enter 0, no coordinates will be logged.
If any other value is specified, only the first <maxCoords> coordinates will be logged.
The maximum number of features logged for this message.
If more features than the maximum to be logged enter the transformer, the features over the limit are not logged.
Note: The Workbench parameter Max Features to Log takes precedence over this transformer parameter.
The Log Feature Type text will set the feature type of the feature just prior to it being logged. If the log file is being saved, the logged features are also saved in a companion FFS file, and this setting is most useful to control the feature type of the features in this FFS file.
If this parameter is left blank, the feature type is constructed from the preceding transformer's name and output port. This can be useful to determine the origin of features when there are multiple Loggers in a workspace, or multiple connections made to the same Logger. For example, if this line appears in the log:
Feature Type: 'MyCreator_CREATED'
it indicates that the feature was output through the CREATED port of a transformer named "MyCreator".
Associated FME function or factory: @Log
Tags Keywords: raster grid band channel palette lookup LUT colormap log describe dump lumberjack Lumberjack
