Reprojects features from one coordinate system to another using the Gtrans reprojection library (from the National Land Survey of Sweden) and the specified translation file.
This transformer relies on Gtrans translation software which is included with FME on Windows platforms.
This is the translation file path.
If raster reprojection is required, a reverse translation file must also be supplied. This parameter defines the inverse translation file path.
The Interpolation Type affects only raster data. Cell values are interpolated in order to change the raster to the specified size.
The Cell Size applies only to raster features.
This transformer ignores the coordinate system set on input features, and does not tag output features with a coordinate system. If you want to take the output of the GtransReprojector transformer and write it to an output format that includes coordinate system metadata, you will need to specify which coordinate system to write, either by using a CoordinateSystemSetter transformer, or by setting the writer's Coordinate System parameter in the Workbench Navigator.
Associated FME function or factory: @Reproject
Tags Keywords: SWEREF99 "National Land Survey of Sweden" Sweden
