Reprojects feature coordinates from one coordinate system to another using the Grid InQuestII reprojection library. This library allows you to use the GridInQuestIIReprojector to transform coordinates between ETRS89 (WGS84) and the national coordinate systems of Great Britain, Northern Ireland and the Republic of Ireland.
This transformer always reprojects from the source coordinate system to the destination coordinate system, tagging the features with the destination coordinate system on output. Any coordinate system set on the input features is ignored.
Choose the source coordinate system
Choose the version of the source coordinate system. You have the choice of 2002 or 2015 versions, which only applies to Great Britain, Northern Ireland and the Republic of Ireland.
Choose the destination coordinate system.
Choose the version of the destination coordinate system. You have the choice of 2002 or 2015 versions, which only applies to Great Britain, Northern Ireland and the Republic of Ireland.
Choose an Irish vertical datum from the list. The parameter is for the regions between Northern Ireland and the Republic of Ireland.
Associated FME function or factory: @Reproject
Tags Keywords: reproject resample raster grid "coordinate system" coordsys "spatial reference" srid georeference
