Renames geometry names or traits.
Features with geometries.
Features with selectively renamed traits or geometry names.
Features that were not modified by the transformer.
Use this parameter if you want to isolate only a portion of the geometry passed in to the transformer. If no criteria are specified, the action will apply to the entire geometry at all levels.
Selection can be based on structural location, geometry name, type, appearance information, traits, trait storage types, or definition reference. The syntax used is a restricted set of XQuery, where the return clause is fixed.
The basic Geometry XQuery dialog allows you to construct simple selection queries by automatically writing the necessary query based on specified test clauses. Clicking the Switch to Advanced button opens the Advanced Editor, which allows you to type a query free-form, for more expressive queries.
Note: Once you switch to Advanced mode, you will have to clear all parameters before you can return to Basic mode.
A hierarchical geometry is represented as nodes of type geometry, with attributes containing information about traits, type, and name for each geometry.
Traits: Rename traits with selected names
Geometry Name: Rename geometries based on name pairs
Specify the exact name pairs to rename: the old name of the trait or geometry and the new name that should be set on those geometries that match the old name or trait. You can enter the names as a comma-separated list (Window,Door) or use the dialog that displays when you click the browse button.
For example, if the old name is “Window”, the new name is “Door”, and you select Traits under Property to Rename, a trait that had the name "Window" would be renamed "Door". The new "Door" trait will retain the original value.
Associated FME function or factory: GQueryFactory
