FaceReplacer
A face is a planar area in 3D space. The planar structure can be a raster, polygon or a donut.
For a raster, the transformer will replace the geometry with a face with the same bounding box as the original raster with a textured appearance using the original raster, as applied from the top view.
The planar area has a concept of a surface normal, a vector that points outwards perpendicular from the area. The direction of the surface normal in a face is determined by using the right-hand rule: if the fingers of your right hand curl along the order of the vertices, the direction that the thumb points to is the direction of the surface normal.
Transformer Categories
3D
Geometries
Technical History
Associated FME function or factory: @GeometryType
Search FME Knowledge Center
Tags Keywords: 3DFaceCreator
