Retrieves the coordinate system of the feature into an attribute.
If the feature has no coordinate system, the attribute will be an empty string.
Features with the extracted coordinate system leave through this port.
The name of the attribute that will record the coordinate system of the feature.
This transformer was renamed from CoordinateSystemFetcher.
Associated FME function or factory: @CoordSys
Tags Keywords: CoordinateSystemFetcher
