Swaps coordinate axes of the input features.
X with Y: Each feature's x-coordinates will be swapped with its y-coordinates.
X with Z: Each feature's x-coordinates will be swapped with its z-coordinates.
Y with Z: Each feature's y-coordinates will be swapped with its z-coordinates.
There are three common uses for this transformer:
Associated FME function or factory: @Affine
Tags Keywords: transform transpose transposer switch
