Reprojects a set of features to a local coordinate system with units of meters centered on the bounding box of the features.
This transformer is useful if you need a number of features reprojected into the same local coordinate system.
If attributes are not specified, all features will be reprojected to the same local coordinate system. If attributes are specified, each group of features will be reprojected to a local coordinate system centered on that group.
Note: How parallel processing works with FME: see About Parallel Processing for detailed information.
This parameter determines whether or not the transformer should perform the work across parallel processes. If it is enabled, a process will be launched for each group specified by the Group By parameter.
For example, on a quad-core machine, minimal parallelism will result in two simultaneous FME processes. Extreme parallelism on an 8-core machine would result in 16 simultaneous processes.
You can experiment with this feature and view the information in the Windows Task Manager and the Workbench Log window.
No: This is the default behavior. Processing will only occur in this transformer once all input is present.
By Group: This transformer will process input groups in order. Changes on the value of the Group By parameter on the input stream will trigger batch processing on the currently accumulating group. This will improve overall speed if groups are large/complex, but could cause undesired behavior if input groups are not truly ordered.
Choose the local projection from the drop-down list based on whether preservation of distances or areas is more important. Choices are:
This parameter determines how Z values will be handled:
Note: Note that rasters can only be reprojected in 2D (that is, with Ignore heights and leave them unchanged).
Local coordinate systems have the following limitation:
Associated FME function or factory: BoundingBoxFactory, TestFactory, @Abort, @CoordSys, @Dimension(), @GlobalVariable, @Reproject, @Value
