Removes leading and trailing trim characters from selected attributes.
The feature type that contains the attribute you want to trim.
Features with the selected trimmed attribute.
After you connect this transformer, click the Browse button and choose from the list of attributes.
Characters may be trimmed from the right, left, or from both sides.
Enter individual characters to be trimmed. Characters will be trimmed from beginning, end, or both the beginning and the end, depending on the Trim Type selection.
If you do not specify a trim character, white space is removed (spaces, tabs, newlines, and carriage returns).
Note: To remove an entire text string, use the StringReplacer.
Characters can be expressed as regular characters but they can also include any number of control characters.
Special character sequences (Advanced Editor only) are interpreted as shown below:
Sequence | Description |
Ctrl+Shift+h (^H) |
Backspace (0x08) |
Ctrl+Shift+l (^L) |
Form feed (0x0c) |
Ctrl+Shift+j (^J) |
Newline (0x0a) |
Ctrl+Shift+r (^M) |
Carriage return (0x0d) |
Ctrl+Shift+i (^I) |
Tab (0x09) |
Ctrl+Shift+k (^K) |
Vertical tab (0x0b) |
You can define special characters through the Basic or Advanced Editors. Click Open Editor from the parameter menu:
Basic Text Editor
Select Constant from the String Type column (or, in some transformers, the Value column) and click on the empty field in the column:
Click the browse button to the right of the column to open an Edit Value dialog. In this editor, enter characters using the shortcut keys from the table above.
Advanced Text Editor
Enter characters using the shortcuts from the table above.
Note: To see tab characters, click the Options menu on the bottom left and select Show Spaces/Tabs.
If a given attribute value contains only Trim Characters, the character that remains depends on the Trim Type: for Both it will be the middle character, for Left it will be the last character, and for Right it will be the first character.
If the Allow Trim Down to Nothing option is set to No, the output of the trimming will have at least one character remaining.
Associated FME function or factory: @Tcl2
Tags Keywords: StringTrimmer
