AttributeFileWriter
Writes the contents of the specified attribute to a file.
Note that if necessary, full pathnames can be created from existing attribute values by using the StringConcatenator to prepend folder names and/or append extensions prior to using this transformer. The resulting attribute can then be used to specify the target file name.
Transformer Categories
Attributes
Format Specific
Workflows
Technical History
Associated FME function or factory: @File
Search FME Knowledge Center
