Copies the value of an attribute whose name is referenced in the source attribute. The value is added to a newly created attribute.
Features with attributes.
Features with a copy of the value of the referenced source attribute.
The attribute containing a reference to another attribute.
The new attribute that will contain a copy of the source attribute's value.
In the transformer parameters:
When you run the workspace, the value 999 (from Attribute B) is added to the destination attribute, as shown in the log file:
2010-11-27 18:13:38| 0.1| 0.0|INFORM|Attribute(string) : `A' has value `B'
2010-11-27 18:13:38| 0.1| 0.0|INFORM|Attribute(string) : `B' has value `999'
2010-11-27 18:13:38| 0.1| 0.0|INFORM|Attribute(string) : `_newAttr' has value `999'
Associated FME function or factory: @CopyAttributes
