Replaces the geometry of the feature with a two-dimensional box whose minima and maxima are fixed values, or are taken from attributes in the original feature.
The minimum X value. You can enter parameters as a number, or choose them from the value of a feature attribute by selecting the attribute name from the pull-down list.
The minimum Y value. You can enter parameters as a number, or choose them from the value of a feature attribute by selecting the attribute name from the pull-down list.
The maximum X value. You can enter parameters as a number, or choose them from the value of a feature attribute by selecting the attribute name from the pull-down list.
The maximum Y value. You can enter parameters as a number, or choose them from the value of a feature attribute by selecting the attribute name from the pull-down list.
To replace a feature with its bounding box in one step, use the BoundingBoxReplacer.
To retrieve the bounds of a feature into attributes, use the BoundsExtractor.
Associated FME function or factory: @XValue, @YValue, @GeometryType
