Temporal value/type:
Note: For convenience, Datetime is often used as a synonym of temporal value.
Interval: A period of time between two temporal values. Example: Date + interval.
The standard FME format for date, time, and datetime values is:
Example: 20170206
Example: 111730, 111730.135
Example: 111730.135-08:00
Example: 20170206111730.135
Example: 20170206111730.135-08:00
Where | Description | Example |
yyyy | 4-digit year | 2011 |
mm | 2-digit month | 07 |
dd | 2-digit day of month | 05 |
hh | 2-digit hour of a 24-hour clock | 14 |
mm | 2-digit minutes | 02 |
ss | 2-digit seconds | 59 |
.123456789 |
Optional fraction of a second, up to 9 digits or nanosecond resolution. Additional fractional digits are accepted, but only 9 fractional digits are kept during temporal arithmetic. Trailing zeros in the fractional digits are automatically trimmed. Only the " |
140259.135 |
UTC offset |
Timezone offset with syntax [+|-]hh:mm (default), [+|-]hhmm, or [+|-]hh. Note: It is a common mistake to misinterpret how UTC offsets are applied. For example, 8PM-08:00 (Pacific Standard Time) is equivalent to 11PM-05:00 (Eastern Standard Time). To get the UTC times, add the negated UTC offset to the unzoned times: 8PM+08:00 = 4AM the next day, and 11PM+05:00 = 4AM the next day. Therefore, @DateTimeDiff(200000-08:00,230000-05:00) = PT0S, meaning the two times are identical in terms of UTC time. |
+00:00 -08:00 -08 |
The FME interval format is based on the ISO 8601 duration format:
See Also
