Statistical Data
dem_type: dem_record_C
This feature contains all the data found within record C. By definition, record C does not contain any geometry; rather, its purpose is to hold statistics about the accuracy of the data within the USGS DEM file.
Attribute Name
Contents
file_datum_stats_avail
The code indicating the availability of the statistics in attributes ‘file_datum_rmse_[x|y|z]’.
0 = unavailable, 1 = available
Range: 0|1
Default: No default
file_datum_rmse_x
RMSE of file’s datum relative to absolute datum (for the x-coordinate).
Range: 0...999999
Default: No default
file_datum_rmse_y
RMSE of file’s datum relative to absolute datum (for the y-coordinate).
Range: 0...999999
Default: No default
file_datum_rmse_z
RMSE of file’s datum relative to absolute datum (for the z-coordinate).
Range: 0...999999
Default: No default
file_datum_sample_size
Sample size on which statistics for attributes ‘file_datum_rmse_[x|y|z]’ are based.
Range: 0...999999
Default: No default
dem_datum_stats_avail
The code indicating the availability of the statistics in attributes ‘dem_datum_rmse_[x|y|z]’.
Range: 0|1
Default: No default
dem_datum_rmse_x
RMSE of DEM datum relative to file’s datum (for the x-coordinate).
Range: 0...999999
Default: No default
dem_datum_rmse_y
RMSE of DEM datum relative to file’s datum (for the y-coordinate).
Range: 0...999999
Default: No default
dem_datum_rmse_z
RMSE of DEM datum relative to file’s datum (for the z-coordinate).
Range: 0...999999
Default: No default
dem_datum_sample_size
Sample size on which statistics for attributes ‘dem_datum_rmse_[x|y|z]’ are based.
Range: 0...999999
Default: No default
