Reader Directives
The suffix shown is prefixed by the current <ReaderKeyword> in a mapping file.
By default, the <ReaderKeyword> for the C++ TFS Fixed Schema reader is TFS_FIXEDSCHEMA and the <ReaderKeyword> for the Java TFS Fixed Schema reader is TFS_FIXEDSCHEMA_JAVA.
DATASET
The value for this directive is the TFS Fixed Schema file to be read. A typical mapping file fragment specifying an input TFS Fixed Schema dataset looks like:
TFS_FIXEDSCHEMA_DATASET /usr/data/tfs_fixedschema/dataset.tfs
Required/Optional
Required
Workbench Parameter
Source Text Feature Store (TFS) Fixed Schema File(s)
ENCODING (C++ TFS Fixed Schema)
This optional specification controls which character encoding is used to interpret text attributes from the TFS_VARIABLESCHEMA file. If the value is not set, then the text attributes will all be interpreted using the system encoding.
Required/Optional
Optional
Mapping File Syntax
<ReaderKeyword>_ENCODING <encoding>
Parameter Description
<encoding>
The character encoding to use when interpreting text attributes. Must be set to any of the following values:
ANSI - this means use the “current OS language”
BIG5
EUC
HKBIG5
ISO
OEM
SJIS
UTF-8
CP437
CP708
CP720
CP737
CP775
CP850
CP852
CP855
CP857
CP860
CP861
CP862
CP863
CP864
CP865
CP866
CP869
CP874
CP932
CP936
CP950
CP1250
CP1251
CP1252
CP1253
CP1254
CP1255
CP1256
CP1257
CP1258
ISO8859-1
ISO8859-2
ISO8859-3
ISO8859-4
ISO8859-5
ISO8859-6
ISO8859-7
ISO8859-8
ISO8859-9
ISO8859-11
ISO8859-13
ISO8859-15
WINDOWS-874
Workbench Parameter
Character Encoding (optional)
SEARCH_ENVELOPE
Using the minimum and maximum x and y parameters, define a bounding box that will be used to filter the input features. Only features that interact with the bounding box are returned.
If all four coordinates of the search envelope are specified as 0, the search envelope will be disabled.
Mapping File Syntax
<ReaderKeyword>_SEARCH_ENVELOPE <minX> <minY> <maxX> <maxY>
Note: If all four coordinates of the search envelope are specified as zero, the search envelope will be disabled.
Required/Optional
Optional
Workbench Parameter
Minimum X, Minimum Y, Maximum X, Maximum Y
SEARCH_ENVELOPE_COORDINATE_SYSTEM
This directive specifies the coordinate system of the search envelope if it is different than the coordinate system of the data.
The COORDINATE_SYSTEM directive, which specifies the coordinate system associated with the data to be read, must always be set if the SEARCH_ENVELOPE_COORDINATE_SYSTEM directive is set.
If this directive is set, the minimum and maximum points of the search envelope are reprojected from the SEARCH_ENVELOPE_COORDINATE_SYSTEM to the reader COORDINATE_SYSTEM prior to applying the envelope.
Required/Optional
Optional
Mapping File Syntax
<ReaderKeyword>_SEARCH_ENVELOPE_COORDINATE_SYSTEM <coordinate system>
Workbench Parameter
Search Envelope Coordinate System
CLIP_TO_ENVELOPE
This directive specifies whether or not FME should clip features to the envelope specified in the SEARCH_ENVELOPE directive.
Values
YES | NO (default)
Mapping File Syntax
<ReaderKeyword>_CLIP_TO_ENVELOPE [yes | no]
Workbench Parameter
Clip To Envelope
