SQLite Non-Spatial Quick Facts
About Quick Facts Tables
Format Type Identifier
SQLITE3
Reader/Writer
Both
Licensing Level
Base
Dependencies
None
Dataset Type
File
Feature Type
Table name
Typical File Extensions
.sqlite, .sqlite3, .db, .sl3
Note that .db and .sl3 are equivalent; however, the .db filename extension is more commonly used. These filename extensions are not exclusive to the SQLite 3 format.
Automated Translation Support
Yes
User-Defined Attributes
Yes
Coordinate System Support
No
Generic Color Support
No
Spatial Index
Never
Schema Required
Yes
Transaction Support
Yes
Encoding Support
Yes
Geometry Type
db_none
SQLite Non-Spatial Geometry Support
Geometry
Supported?
aggregate
no
circles
no
circular arc
no
donut polygon
no
elliptical arc
no
ellipses
no
line
no
none
yes
point
no
polygon
no
raster
no
solid
no
surface
no
text
no
z values
n/a
