Schema (From Table) Quick Facts
Format Type Identifier | SCHEMAFROMTABLE |
Reader/Writer | Reader |
Licensing Level | Base |
Dependencies | None |
Dataset Type | Reader: File, Folder, URL or database name |
Feature Type | schema |
Typical File Extensions | Depends on reader |
Automated Translation Support | Yes |
User-Defined Attributes | No |
Coordinate System Support | No |
Generic Color Support | No |
Spatial Index | No |
Schema Required | No |
Transaction Support | No |
Encoding Support | No |
Geometry Type | fme_type |
Geometry Support |
Geometry |
Supported? |
Geometry |
Supported? |
aggregate | not applicable | point | not applicable | |
circles | not applicable | polygon | not applicable | |
circular arc | not applicable | raster | not applicable | |
donut polygon | not applicable | solid | not applicable | |
elliptical arc | not applicable | surface | not applicable | |
ellipses | not applicable | text | not applicable | |
line | not applicable | z values | not applicable | |
none | not applicable |
In all cases, the geometry is passed untouched to the writer chosen at runtime, which may or may not support all geometry types.
