SAP Sybase Adaptive Server Enterprise (ASE) Reader/Writer
Licensing options for this format begin with FME Professional Edition.
The SAP Sybase Adaptive Server Enterprise (ASE) reader and writer modules provide FME with access to attribute data held in SAP Adaptive Server Enterprise database tables. FME provides read and write access via SAP's jConnect driver, which must be installed separately.
The jConnect driver can be found in the SAP Adaptive Server Enterprise program folder, and is usually named jconn4d.jar. SAP Adaptive Server Enterprise can be downloaded from SAP’s official webpage.
Note: jconn4.jar can also be used if jconn4d.jar is not available.
jconn4d.jar needs to be placed in one of the locations that are added to the Java CLASSPATH when the Java Virtual Machine is loaded.
For help with installing the JDBC driver for FME, please see Getting Started with JDBC.
