RDB_Project Quick Facts
Format Type Identifier RDB_PROJECT
Reader/Writer Reader
Licensing Level Professional
Dependencies RDB, XML
Dataset Type File
Feature Type RDB_PROJECT
Typical File Extensions .rpp, .rsp
Automated Translation Support Yes
User-Defined Attributes No
Coordinate System Support No
Generic Color Support No
Spatial Index No
Schema Required Yes
Transaction Support No
Encoding Support No
Geometry Type fme_type
Geometry Support
Geometry Supported?   Geometry Supported?
aggregate no   point no
circles no   polygon no
circular arc no   raster no
donut polygon no   solid no
elliptical arc no   surface no
ellipses no   text no
line no   z values yes
None no   point cloud yes
Point Cloud Component Data Type Notes
fmepc_angle INT8 ScanAngleRank (-128..127) in degrees. Only in P3D.rds version 3.0.
fmepc_classification UINT8 Classification from LAS Standard 1.3. Only in P3D.rds version 1.1+.
fmepc_color_r UINT8 From optional RGB file
fmepc_color_g UINT8 From optional RGB file
fmepc_color_b UINT8 From optional RGB file
fmepc_flight_line_edge not supported
fmepc_flight_line not supported
fmepc_gps_timeUINT64 UINT64 Timestamp. Retrieved either from data file or optional TST file
fmepc_gps_week not supported
fmepc_intensity INT16 Reflectance or amplitude
fmepc_number_of_returns UINT8 TargetCount. Only in P3D.rds version 2.2, 3.0.
fmepc_point_source_id UINT32 SourceIndex. Only in P3D.rds version 2.1, 2.2, 3.0.
fmepc_posix_time not supported
fmepc_return UINT8 TargetNumber. Only in P3D.rds version 2.2, 3.0.
fmepc_scan_direction not supported
fmepc_user_data not supported
